Effaceur d'erreur OBD, j'en ai acheté un
MessagePosté le: 02 Juil 2007 21:43    Sujet du message: Effaceur d'erreur OBD, j'en ai acheté un Répondre en citant
Brand New OBD II OBD2 Check Engine Code Reader
We are selling this brand-new quality product at the factory price!
Our Code Readers Are the Most User-friendly with Easy-to-read Crystal-Clear Back-lit LCD Display
VEHICLE COVERAGE
Make Model Year Protocol Fuel Type Country
Alfa 147 2004 ISO Diesel Italy
Alfa 147 2005 ISO Diesel Italy
Alfa Romeo 156 2.0 JTS 2003 ISO
Alfa Romeo 166 1999 ISO Diesel Belgium
Alfa Romeo Spider 2001 ISO
Alfa Romeo Spider 2.0 2001 ISO Gasoline Germany
Alfa Romeo Spider 2.0 TS 2001 ISO Gasoline United Kingdom
Postage: Airmail+Reg (need 10-14 days)
Pack include:
1) 1 PC OBD2 Engine Code Reader
2) User's Guide(Code List)
Brief Introduction
If your car's Check Engine Light is on, you need this device. Geniscan Code Reader is a handy device for car-owners, DIY customers and even professional technicians to read OBD II diagnostic trouble codes (DTCs) from the on-board computers of 1996 and newer vehicles. With this smart reader, you are able to immediately self-troubleshoot the cause of the "Check Engine" light at any moment wherever you are. The Geniscan will also enable the user to erase the trouble codes and shut off (reset) the check-engine light as soon as the vehicle is repaired.
Features and Benefits
Works with all 1996 and newer cars & trucks that are OBD II compliant
Reads and clears generic and manufacturer specific Diagnostic Trouble Codes (DTCs) and turns off check engine light
Supports multiple trouble code requests: generic codes, pending codes and manufacturer’s specific codes
Highly reliable and accurate
Easy-to-read crystal-clear backlit 2-line LCD display
Easy to use with one plug-in
Stand-alone unit with no need for an additional laptop computer to operate
Small in size and conveniently fits in your palm
Performs continuous DTC scan
Safely communicates with the on-board computer
No batteries needed-powered via detachable OBD II cable
One-year warranty
Will This Code Reader Work with My Car? (Must Read )
The Geniscan OBD II Code Reader is specially designed to work with all OBD II compliant vehicles. It is required by EPA that All 1996 and newer vehicles (cars and light trucks) sold in the United States must be OBD II compliant and this includes all Domestic, Asian and European vehicles.
A small number of 1994 and 1995 model year gasoline vehicles are OBD II compliant. To verify if a 1994 or 1995 vehicle is OBD II compliant, check the Vehicle Emissions Control Information (VECI) Label which is located under the hood or by the radiator of most vehicles. If the vehicle is OBD II compliant, the label will designate “OBD II Certified”. Additionally, Government regulations mandate that all OBD II compliant vehicles must have a “common” sixteen-pin Data Link Connector (DLC).
For your vehicle to be OBD II compliant, it must have a 16 pin DLC (Data Link Connector) under the dash and the Vehicle Emission Control Information Label must state that the vehicle is OBD II compliant. This label is located on the inside of the hood on most vehicles.
VEHICLE COVERAGE
GM '96 - Current Year (OBD-II)
Ford '96 - Current Year (OBD-II)
Chrysler '96 - Current Year (OBD-II)
Toyota '96 - Current Year (OBD-II)
Honda '96 - Current Year (OBD-II)
NISSAN '96 - Current Year (OBD-II)
All other Asian and European '96 - Current Year (OBD-II )
How to Use
When your "Check Engine" light or "Service Engine Soon" or “Check” light is on, stop the car and apply the parking brake, start the engine, and then plug the Geniscaner code reader to the 16-pin diagnostic socket(universal connector) usually located under the instrument panel in the car.
Push the Read button and it automatically gets the Diagnostic Trouble Codes (DTCS) if any in less than 10 seconds.
Identify the trouble codes and retrieve their detailed descriptions by looking up the Diagnostic Trouble Codes(DTCS) list in the enclosed user’s manual.
MessagePosté le: 02 Juil 2007 21:44    Sujet du message: Répondre en citant
23e port inclus, j'ai demandé a des acheteurs passés de ce produit, ils m'ont dit en etre super contents.....
a voir a l'usage
MessagePosté le: 02 Juil 2007 22:00    Sujet du message: Répondre en citant
Hummm...
MessagePosté le: 02 Juil 2007 22:01    Sujet du message: Répondre en citant
ben oui, moi aussi
cyrille
MessagePosté le: 02 Juil 2007 22:11    Sujet du message: Répondre en citant
La même chose que , pour moins cher et en plus pratique, mais sans possibilité de faire de l'aquisition de données pour jouer comme ici
grizzzzly
MessagePosté le: 02 Juil 2007 22:13    Sujet du message: Répondre en citant
perso j'utilise le g400 est c'est vraiment top
ca aide bien en cas de probleme a dire ce qui deconne ou a effacer les defaut en cas de fausse manip en bricolant razz
steph l'incovenient par contre du tient c'est qu'il te donne juste un num et apres il faut rechercher dans la liste le defaut auquel ca correspond alors que le model 400 lui le dafaut est ecrit en texte avec toutes les données moteur au moment du defaut (temp, vitesse, regime......)
au passage la liste est sur mon ftp aussi
http://grizzzzly.free.fr/alfa/diagnostic/liste%20DTC%20fr.pdf
ex 147 GTA Q2 Ragazzon gr N boitier Fga, Koni FSD, EBC RedStuff, embrayage renforcé sachs performance
Camaro 2010 v6 et Touareg v8
Voir le profil de l'utilisateur Envoyer un message privé Visiter le site web du posteur Adresse AIM
MessagePosté le: 02 Juil 2007 23:09    Sujet du message: Répondre en citant
en effet, moins cher, plus facile mais pas du tout les mêmes prérogatives, quand l'un peut jouer sur les données, l'autre se contente de constater et simplement effacer, mais pour 23e et sans bidouille, c'est ce que je cherchais
pour le g400, je le voulais aussi au départ, mais un poil cher pour ma bourse
en fait, je cherchais un truc pour juste enlever le voyant d'airbag en cas de fausse manip sur les tests du circuit electro, pour effacer les erreurs injection ou des trucs du genre
un grand merci pour la liste de codes par contre cool
pis en plus, les mondeos du boulot sont en obd2 aussi mdr
grizzzzly
MessagePosté le: 02 Juil 2007 23:17    Sujet du message: Répondre en citant
je pense que ca doit etre comme le mien tu ne pourras lire que les codes liés au groupe moteur donc pour le voyant airbag tu ne pourras rien faire c'est sur une autre ligne pas_cool
MessagePosté le: 02 Juil 2007 23:18    Sujet du message: Répondre en citant
flute, bon ben tant pis
cry
cyrille
MessagePosté le: 02 Juil 2007 23:22    Sujet du message: Répondre en citant
C'est pas faute de l'avoir dit 15 fois....
MessagePosté le: 02 Juil 2007 23:26    Sujet du message: Répondre en citant
avoir dit quoi? mdr crazy
Samy
MessagePosté le: 02 Juil 2007 23:44    Sujet du message: Répondre en citant
En effet, c'est ballot!!!
par contre, c'est assez dingue le nombre de codes défaut possibles!!! Est-ce que cela veut dire que tous ces paramètres sont contrôlés en permanence. Parce que là je me dis que c'est impossible que tout fonctionne bien en même temps étant donné le nombre!!!!
doudoudu25
MessagePosté le: 04 Juil 2007 17:27    Sujet du message: Répondre en citant
Dis toi qu'a chaque code erreur correspond une action du moteur, ou de la voiture...
Il n'y a guère plus de fonctions qu'avant dans nos voitures (hormis les ordinateurs de bords)...
Les injecteurs, les faux contacts en tout genre... il y en a dans toutes les voitures, multiplexées ou non.... mais c'est juste que la, les anomalies sont répertoriées dans la centrale dès que le dysfonctionnement apparait....alors qu'avant il falait les chercher une par une....
EX : 147 TS 120 "quasi Ti"
Samy
MessagePosté le: 07 Juil 2007 23:50    Sujet du message: Répondre en citant
cool cool
MessagePosté le: 08 Juil 2007 00:38    Sujet du message: Répondre en citant
Alors moi j'ai mon témoin d'airbag allumé depuis... octobre 2004 triste
douds
MessagePosté le: 08 Juil 2007 11:21    Sujet du message: Répondre en citant
c'est comme cela qu' on entretient sa Belle !!
oh
Dbonin
lol
ex JTDM 120 Eleganza...now Honda Watture
MessagePosté le: 23 Juil 2007 22:39    Sujet du message: Répondre en citant
bon ben apparemment, ça ferait un peu plus que les simples erreurs moteurs
ça passe sur 147, ford mondeo, clio, kangoo, master
j'attends d'avoir le temps de traduire les douze milles pages de codes afin de savoir ce que ça peut faire, mais ça semble efficace
chriser
MessagePosté le: 23 Juil 2007 23:27    Sujet du message: Répondre en citant
tu l'as acheté où et pour combien ??
ALFA 159 Sport 1.9 JTDM 150
Ex ALFA 147 Distinct 1.9 JTDM 120@172 O² Down Pipe + jantes Ti + coque rétro alu
Maintenant 2 italiennes @ home, pas vrai chérie!
Ma belle en photos, et en couleur s'il vous plaît
MessagePosté le: 23 Juil 2007 23:30    Sujet du message: Répondre en citant
http://search.ebay.com/gs400-obd_W0QQ_trksidZm37QQcatrefZC6QQfromZR10QQfsooZ1QQfsopZ1QQftrtZ1QQftrvZ1QQpqryZgQ20400Q20obdQQsabfmtsZ1QQsacatZQ2d1QQsaprchiZQQsaprcloZQQsofocusZbs
Page 1 sur 2
